It is currently Tue Aug 05, 2025 6:43 pm
PostPosted: Thu Feb 19, 2009 4:44 pm
One of the popular books on Classical Guitar construction says to glue the sides into the heel slots. I've built many ukuleles and never glued the sides into the heel slots. What do you do?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu Feb 19, 2009 5:22 pm
Don't glue, but I do use the Romanillos double wedge system.
PostPosted: Thu Feb 19, 2009 5:24 pm
Classical guitar are mostly built with spanish heel necks that have a slot (narrow datto) on eaach side of the heel block wher the sides slip into. In other words the neck and neck block is one piece with narrow mortices wher the sides fit into the neck.
PostPosted: Thu Feb 19, 2009 6:05 pm
I glue...but only on inside surface of side. Putting glue on outside surface of side creates risk of glue squeeze out around heel area.
PostPosted: Thu Feb 19, 2009 6:06 pm
Ya I got that Michael, question was whether to glue the sides in or not.
Rich Smith
Issaquah, WA
PostPosted: Thu Feb 19, 2009 6:31 pm
hi Ricardo
timely question, this is the stage I’m at today.
The slots are “angled” very slightly from the body side back to the twelve fret mark and also (viewed from the side of the neck block) there is a very slight diagonal incline so the neck “leans forward” a few degrees depending on your solera layout.
The saw has been modified to hold two blades to give the correct width of cut to accept the sides.
hope this helps
Geordie
oh I just saw your reply. It will be glued but the next one will be wedged.
some tunes on acoustic and guitar synth.
http://www.youtube.com/user/TheGeordieAdams
http://www.myspace.com/geordieadams
PostPosted: Thu Feb 19, 2009 6:46 pm
Most do glue Ricardo.On the inside only.
PostPosted: Thu Feb 19, 2009 6:54 pm
Last Name: Killin
I can't remember where I read to do it, but I just used some Paper\Carboard and wedged it tight (on a uke). I didn't use any glue. If I were doing it now I would probably use some wedges made of wood. I don't think the paper gave me even pressure along the entire joint and when I carved the neck I ended up with some slight gaps. This could have been my lack of understanding of the entire process. Like I said if I had to do it again, I would do it differently. But I don't think there would be a need for glue.
In hindsight, what I should have done when I notice the gap would have been to pull the paper and put another wedge in there to get it tight. If I had used glue, that wouldn’t be possible, or would be more difficult. While I was doing the original assembly I had some issues and had to give it a try several times. Not having glue in there worked to my advantage at that point.
Good Luck,
PostPosted: Thu Feb 19, 2009 8:35 pm
First name: Josh
Last Name: French
City: Houston
Romanillos double wedge with glue here.
Instagram: @jfrenchluthier
PostPosted: Thu Feb 19, 2009 8:53 pm
I do not glue the sides into the heel. I cut the slot using a 2.1mm thin kerf blade. The side fit snugly into the slot, no glue.
PostPosted: Thu Feb 19, 2009 10:00 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Double wedge glue on the inside. I learnt the hard way about glue squeeze out on the outside...
http://redrivercanoe.ca/
PostPosted: Thu Feb 19, 2009 10:49 pm
What does the Romanillos double wedge look like? I think some use wedges put in verically whereas others push wedges in from the side (horizontally). I used vertical wedges in my ukuleles.
Rich Smith
Issaquah, WA
PostPosted: Thu Feb 19, 2009 11:08 pm
Here you go, Ricardo.
PostPosted: Thu Feb 19, 2009 11:29 pm
Waddy,
Bless you for thoso photos. I have been, this very evening, scratching my head trying to visualize the double wedge. I have been flummoxed as to what to do. Now I have everything I need to complete this operation and I see that I have not ruined my neck after all!!!!
Very nice.
http://www.booneguitars.com
https://www.facebook.com/pages/Stephen-Boone-guitar-builder/488208541257210
PostPosted: Thu Feb 19, 2009 11:45 pm
Thanks Waddy. [:Y:] [:Y:]
Rich Smith
Issaquah, WA
PostPosted: Fri Feb 20, 2009 3:50 am
For me the wedges are glued but not the sides.
PostPosted: Fri Feb 20, 2009 6:59 am
Stephen, you defiantly don't want to be flummoxed when preparing your neck joint, it could be fatal!.
We want more words like FLUMMOXED!
Geordie
PostPosted: Fri Feb 20, 2009 8:30 am
When I make the Romanillos style, like Waddy's picture, I put glue on both sides of the wedge that is put in last which leaves the sides without glue. When I do the standard slot style, I don't use any glue.
PostPosted: Fri Feb 20, 2009 11:16 am
I glued the wedges in, but not the side to heel, outside the box.
PostPosted: Fri Feb 20, 2009 11:44 am
First name: Wendy
Last Name: W
State: Arizona
Hey Waddy, thanks for those pictures. Would you be willing to share your system for cutting the wide slots. I've been cutting just the narrow ones by hand and I'd rather switch to the double wedge. Do you cut them on a table saw? On another note, I thought that I had 3 necks I have been working on completed. I had finished carving the heels last weekend, and yesterday I took a good look in some bright light and realized I had removed too much wood from the heel of one gaah ! I'm going to try to cut the heel off and glue on another heel block and recarve. It means recutting the slots so I might as well switch now. Thanks, Wendy
PostPosted: Fri Feb 20, 2009 12:07 pm
So far, my experiences of cutting the slots any other way than by hand has been a disaster. I ruined 2 V-jointed necks trying different methods, and went back to hand cutting. I'm sure there is a way, but I have not successfully found it. Check out my build album for #2, and you can see my failures. My albums contain all of the successes and failures of my builds. They are, after all, my build logs. The link to all of my albums is in my signature.
If I'm not mistaken, David La Plante has a Tutorial in the Tutorial section on his jig for cutting those slots. I tried that and failed too. Not a problem with David's jig, just "Operator Head-space"! [headinwall] :oops:
PostPosted: Fri Feb 20, 2009 12:16 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks Waddy, I looked at your pictures from your 2nd. I guess I'll go ahead and cut by hand and chisel out. I'll check out David La Plante's tutorial too. How wide are your slots? Thanks, Wendy
PostPosted: Fri Feb 20, 2009 2:26 pm
I tried the techniques link at the top of the OLF page but apparently the link is broken. If it is impossible to fix this why not just take the links off?
Rich Smith
Issaquah, WA
PostPosted: Fri Feb 20, 2009 2:40 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
If you are working in Spanish Cedar or Mahogany, it is very easy to do by hand. In fact, its a treat do do it by hand. A good saw and a sharp chisel, that's it. Only think that I'd advise is that you consider the width of the slot relative to the width of your chisel. Its easier working in a slot that is bigger, rather than smaller, than the chisel that you choose to work with.
It may seem obvious, but only after you try and do the job, or someone points it out to you. Me, it was obvious while I was cutting it...that's how I know now!
PostPosted: Fri Feb 20, 2009 2:55 pm
Generally the slots are 10mm wide, but I don't know that it's a critical measurement. Here is a link to David LaPlante's Thread on Working up a Classical Neck, which should, without a doubt, be placed in the Tutorial Forum. It shows his jig for cutting the slots. It works well if you use it right, which I did not, the first time.
viewtopic.php?f=10101&t=16461&hilit=+slots
